Magnafluxing or crack checking info
Looking for someone that has either done one of these or is very familiar with the process. Twenty some years ago when I went to School for auto tech we magnafluxed with a hand size magnet and the powder, a few years back the machine shop I was using (from an auto parts supplier) used the same technique when I brought in a couple of blocks to be cleaned and checked out. (they have since closed their machine shop). What I am trying to find out is where I can get the magnet or what size or style I would need, I found the powder but the parts house says I have to have an expensive electro magnet ($500.00 +) and I know for a fact the guy that did it at the machine shop had just a hand sized hand held magnet because we walked out to my truck and checked some common crack areas before even unloading it and the cracks showed up right away. Someone also told me recently that there was a liquid you could get to test them but they couldn't remember the name, I have a few blocks and several heads I would like to check before deciding what I'm going to do with them. Thanks for any info I can get.
Goodson sell automotive shop equipment...
http://www.goodson.com/ |
Thanks for the info guys but as I said I remember seeing the guy at the machine shop do this with just a large (about hand size) magnet before we even unloaded it and I'm almost sure it wasn't an electro magnet. Has anybody seen this or have any info about what size magnet it woul take ?
I've see those also. I don't know how trustworthy those types are, especially if the block or heads are still greasy. I believe Goodson made a handheld one like you are descibing. I saw that someone had posted a link earlier to them so you might check them out.
Looks like $500 might be a bargain.
http://www.goodson.com/store/templat...e0b1b485a186e8 Dye pen may be the way to go. http://www.goodson.com/store/templat...e0b1b485a186e8 |
I already checked them out, the one they have is a little bigger and again has to be plugged in (electo magnet). What I'm looking for is basically a strong U shapped magnet. As far as reliability, on these particular parts I have some suspect areas that I can't confirm one way or another and none of them had other symtoms but I would like to try to confirm before deciding what to do with these. One had upper valve train problems, one has minor imperfections and discoloring on deck from a blown head gasket. I would like to sort of pre check these as well as others in known problem areas and suspect areas. The one he used imediatlely showed a small 1 inch crank on a deck and another with a crack across the top of the lifter valley.
Redsdad saw your post after I did the previous reply. That might work I'll have to give them a call and see. I'm still trying to track down the machinist that worked for the machine company that did my other blocks to see if he has any info on what he was using.
I've done both. They each have their advantages and disadvantages. I was actually certified for a while in dye pen (low level cert - couldn't do Code vessels). IMHO, PT is messier but less cumbersome. Based on the cost and relative ease of use, I think I would go dye pen.
| Buick Trannie info needed | SquirrelWolfs | Transmission - Rearend | 2 | 08-12-2007 03:42 PM |
| Custom intake tube info (Cavalier, but good info for all) | TheVis | Engine | 11 | 02-09-2007 04:44 AM |
| Need info about the th350 transmission | joe350s10 | Transmission - Rearend | 1 | 07-01-2006 09:44 PM |
| info on turbocharging engines | crshrmn3 | Engine | 4 | 12-20-2002 12:27 PM |
| 400 SBC Balancing and info ? | Brobob | Engine | 8 | 10-31-2002 03:44 PM |
