Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - main bearing
Thread: main bearing
Old 01-18-2005, 06:34 PM
Jmark's Avatar
Jmark Jmark is offline
Someone told you something really wrong. Changing the bearings by 10 thousands will cause it to either seize up or to knock like crazy, depending which you need and which you actually use. If the crank needs .020 bearings, that is what you need to buy. Take it to a good shop and have them mike the crank and tell you whats up.
Mark
