main bearing noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2003, 11:16 AM
Post main bearing noise
sbc 350 so my engine my buick has been running great up to this point? well its still running great with noise. ok here is what i have main bearing noise as soon as i starter up. oil pressure upon start up is around 50(oil sensor on back of block behind intake used coper line if that helps didnt want to use the plastic)when it warms up it drops to around 25 is my oil pressure low because of where the sensor is or is it just low ,melling oil pump from orlieys. also i hear the noise at about 2500 to 3000. as soon as i can find a garage to work on it. or a good few days comes around ill dig in.if it helps the machine shop polished the crank reputable(sp) machine shop
Old 01-12-2003, 03:21 PM
Question
What makes you think It's a main bearing?. Oil pressure doesn't sound bad to me. Need more history could be as simple as valve adjustment.
Old 01-12-2003, 03:35 PM
project69ss's Avatar
Post
Had a crack in a flex plate that once did that to me,sounded like a rod bearing gone.beat my head in figuring that out.
Old 01-13-2003, 03:29 AM
Post
someone esle said that it could be the flex plate
Old 01-13-2003, 03:33 AM
Post
there is also a lifter tick just upon start up no oil pressure maybe <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
Old 01-13-2003, 03:58 AM
Tazz
Cool
They sell engine flush to remove grime and help sticking lifters. There is a danger to these products though, they can remove the deposits that are ALLOWING you engine to run without smoking. You could be taking a chance using them. If your worn Main brngs are knocking it is a loud knock knock that does not go away. Sometimes a piston will slap, that noise will go away but without a complete REBUILD you will now know for sure what your problem is.
Todd
Old 01-13-2003, 10:11 AM
Post
if you say that a main bearing noise is consistant then thats not the problem ,but its always there around 2500-3000 after that no problem could it be the timing chain remeber it only has 2000 miles on it ? i get to use a friend of mine garage this weekend and im going to dig in thanks for the help.
