main bearing questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2012, 02:24 PM
What are undersize and oversize bearings.my crank was turned. 010 so i would need oversize right since there should be .010 more bearing metereal
Old 11-28-2012, 02:27 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
.010 under for describing bearings.
.010 over for describing pistons.. (.010 .020 .030 etc)
Old 11-28-2012, 02:32 PM
Well my local parts store has them for over and undersize main bearings
Old 11-28-2012, 02:49 PM
C-10's Avatar
Revolution Calling
Mic the crank. Use the numbers/size to buy bearings.
Old 11-28-2012, 04:32 PM
1971BB427's Avatar
If you tell the parts store your crank was turned .010" under and they don't know what bearings to sell you, then I'd either get another salesman, or another parts store.
Old 11-28-2012, 06:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
As said earlier you want 0.010" undersize bearings. The package will often have -10 as a suffix, or just 10.
The individual bearing shells are also marked for size. The King bearing below is a 0.010" undersize bearing:
There are 0.001" and 0.002" oversized bearings, sometimes used to selective fit bearings to journals for a closer tolerance. These are called X and XX bearings, respectively. I'm not aware of over the counter oversized bearings for a SBC that would be 0.010".
Old 11-28-2012, 07:22 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
While we are on the topic of bearings,here is a link on the difference kinds of bearings to choose from:
Getting Your Bearings: Engine Builder
Main bearing question hotrod688 Engine 20 01-26-2010 07:40 PM
main bearing help schottout Engine 4 09-26-2009 08:16 PM
fe main bearing james diel Engine 7 01-27-2006 04:57 PM
main bearing AMP Engine 5 01-18-2005 06:47 PM
main bearing bolt violent j Engine 3 07-10-2004 08:34 PM
