-   -   main Bearing wear (http://www.hotrodders.com/forum/main-bearing-wear-199209.html)
bill plise 05-25-2011 09:25 PM
main Bearing wear
Hi guy's, I've got a couple of questions and would appreciate any help you can give me. Im rebuilding my 76 corvette motor and after pulling the crank I notice some wear on the bearings which Im sure is normal but the rear larger bearing appears to be worn a little more so than the other bearings. all rod and main journals look really good with the exception of the rear which has two small nicks that I can see but cannot feel. The rear bearing is not scratched but like the rest, there is some bearing face wear. Does the rear usually wear a little more than the rest? The pistons are 030 over and the rods and mains are 010 over. This motor has been sitting for the last 20 years but was supposedly rebuilt just before it was taken out. I don't know if the bearings were replaced but it sure doesn't look like it. Bill.
cobalt327 05-25-2011 09:41 PM
Some tight in-focus shots will help a load in showing what might be up w/the bearings, etc. But I/m not hearing anything that would lead me to believe there was something obviously wrong.
oldbogie 05-26-2011 11:35 AM
One would expect to see overlay gone in various places. A typical tri metal bearing is a steel backing with a copper alloy and a flash plate of lead, or Babbit. or indium which provides a soft start up layer when the assembly is new and not yet oil soaked. The copper takes the heavy load and transfers it to the steel backing which puts it into the cap. The flash will wear in odd ways depending upon the machine fit of the bearing and journal mate and with the loads that distort both he block and crank. The crank whether internal or externally balanced really isn't balanced at each bearing bay, the balance is an overall thing. So there are local out of balance loads the cause specific journals to want to run somewhere beside where the bearing is holding them, this affect is reflected in the bearing wear. The crank wants to whip its ends so usually there is more action on the outboard bearings than you'd expect to see unless you know this, this is why the biggest counterweights are on the ends. The number 5 main is also reacting the thrust loads and especially where a clutch is being used sees some bending loads through the journal so the rear main tends to look kind of beat up. For the most part the wear should be in millionths of an inch to 10thousandths of an inch compared to non or minimum wear areas, you can check this in specific areas by measurement or with plasti-gage. Pictures are help full in us being able to see what you are seeing. But as long as the bearings aren't showing discoloration or spider webbing from excess heat, or cratering from excess loading, or heavy wear or grooving from grit, the wear you describe sounds like close to normal, but not consistent with the claim of a recent rebuild.
Bogie
