main bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2007, 06:53 PM
main bearings
if you get a block line bored for crankshaft.not the cylindes,and the crank is turned.then you need 010 over and 010 under?? thanks
Old 04-30-2007, 06:58 PM
poncho62's Avatar
Wiki Edits: 5
When they line bore a block, they remove a little from the caps, so the hole ends up the same size. If you turn the crank, it will need undersize bearings.
Old 04-30-2007, 08:46 PM
BOBCRMAN@aol.com's Avatar
Poncho is correct in a general way. Then you can get into split case motors and/or cracked rod motors.
These would have oversized outer bearing shells with undersized crank surfaces. Common on old VW's and newer cars.
383 main bearings?? gods_flame03 Engine 1 04-29-2007 07:39 AM
Main bearings, crush? fiscus Engine 3 01-28-2007 01:51 AM
Main Bearings k-star Engine 5 07-22-2004 05:41 PM
Main bearings fried NorthStar Engine 8 02-18-2004 03:54 PM
.001 oversize main bearings from factory crshrmn3 Engine 2 01-02-2003 08:46 PM
