-   -   Main Bearings (http://www.hotrodders.com/forum/main-bearings-43954.html)
k-star 07-22-2004 12:20 PM
Main Bearings
Ok it's opinion time...
On a non-cross drilled crank. What main bearings do you run, or have you run with good results
1/2 groove
3/4 groove
full groove
Application is a big block mopar, with factory steel crank.
Keith
johnsongrass1 07-22-2004 01:48 PM
How many RPM? Power? Intended use? How bout reliabilty? Is it a concern?
Normall I run the full groove bearings to reduce friction loss. But they don't seems to last as long.
k-star 07-22-2004 01:57 PM
MORE
6800/7000 ish, should be in the 625 to 650 hp range. drag with some limited street time. It will probably get freshined every year.
keith
Cstraub 07-22-2004 03:16 PM
Keith,
3/4". That comes from a couple of customers that fool with the Chryslers and hold a few NHRA records.
Chris
machine shop tom 07-22-2004 03:38 PM
The Federal Mogul 3/4 groove mains seem to work quite well; they negate the need (if any) to cross-drill the crank.
tom
johnsongrass1, fully groove mains have a severely compromised bearing film from the groove in the bottom half. That's why they don't last as long and why I don't use them unless they are the only thing available for a given engine.
k-star 07-22-2004 05:41 PM
bearings
Thanks Tom and Chris,
I was leaning to the 3/4 groove but i read in a chrysler builders book that they suggest full groove. I am with tom i don't like the fact that i am going to loose aproximently 1/4 of my load bearing surface with a full groove bearing. But i do understand the importance of feeding those large rod journals with plenty of oil. So i was thinking the 3/4 would be a "best of both worlds" situtation..
Keith
