main cap studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2010, 07:07 PM
main cap studs
HELLO ALL, I was told that by installing studs in a block that it will distort the caps and the block will need to be align bored.To me this doesn't make sense .Aren't bolts and studs dong basically the same thing? wouldn't the torque specs be the same? Thanks........
Old 12-11-2010, 07:51 PM
ericnova72's Avatar
More for Less Racer
Usually a stud (or and aftermarket bolt) is made of a higher quality stronger alloy steel than the factory bolt, even at the same torque level it will distort the bearing bore differently than the "stretchy-er" factory bolt. On top of this, aftermarket bolts often have a higher torque value than factory bolts, which also influences the distortion amount.
Old 12-11-2010, 08:02 PM
I am in sort of the same boat. I was planning on installing ARP studs in my 2-bolt 454. However, if that is going to require a line bore anyway, I might consider finding some stock 4-bolt caps cheap and having the additional work done.
The 400 SB I had work done did need a line hone (and not a line bore) after the main studs were installed. At least that is what my machinist told me. Did I just get lucky with that?
Old 12-11-2010, 08:07 PM
ericnova72's Avatar
More for Less Racer
Generally the addition of studs will only require a line hone, my 400's and 383's have been that way.
Old 12-12-2010, 11:57 AM
Any old block that is going to be used in a performance application should be line honed period and read the instructions that come with the ARP stud or bolt kit as it pretty much laid out.
Here is the bearings out of a 327 chevy with 400 miles on the engine and it came if for other reasons but we did line hone the block and this summer this vette went to all 48 states in 89 days 21000 miles and no issues.
Stock main cap bolts BringBackTheCamaro Engine 2 03-09-2006 01:36 PM
rtv silicone in rear main cap? spyderdude Engine 2 08-21-2005 07:39 PM
Main cap problem on NEW motor,,,,,,what the @*!$& do I do now????? STATUTORY GRAPE Engine 13 06-26-2005 09:15 PM
Main cap girdle shagginwagonvic Engine 4 11-19-2003 10:08 PM
in need of # 5 400 main cap lamberson3500 Engine 4 08-25-2003 08:07 PM
