There shouldn`t be any difference. Large journals didn`t come along until 1968. What`s the casting numbers for both your engines? Check the main caps on both engines and see if there`s any difference in there height.
Thanks for the info, but when I tried to transfer the main cap bolt (same bolt location) from the 283 to the 327, it was too short to reach any threads. Do you happen to know what length they should be?
For two bolt SBC main caps, there are only 2 lengths- for SJ and LJ (including the 400 SBC).
A LJ bolt measures 3-3/8" from the end to the underside of the hex head. Are you sure you don't have the head bolts mixed up in the main cap bolts? lol Last edited by cobalt327; 04-23-2010 at 01:52 PM. |
FWIW, the LJ block has 1-3/8" of bolt extending below the bottom of the main cap.
So if you were to measure the main cap of the SJ block from the bolt pad to the bottom of the cap and add about 1-3/8", this should be very close to the bolt length required for the SJ caps. |
Good luck. |
![]() Only thing left is to find some SJ bolts. |
| "Basics of Basics" Nuts and bolts | MARTINSR | Hotrodding Basics | 10 | 06-28-2010 05:38 PM |
| sbc build. dressing for main bolts? | callmejavier | Engine | 6 | 06-29-2008 10:47 AM |
| Need help with main caps | Monster_215 | Engine | 4 | 05-19-2008 04:57 PM |
| Stock main cap bolts | BringBackTheCamaro | Engine | 2 | 03-09-2006 01:36 PM |
| Windage trays....... | onebadmerc | Engine | 70 | 01-04-2005 06:57 AM |
