Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - main or rod bearing rap.
Old 11-16-2012, 05:06 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Do you have a bore guage to measure the inside of the big end without the bearings inside but the bolts tight.
Maybe even a caliper will work if your real careful and try it several times to make sure you get a good number. I got a feeling the rod bolts were changed without rod resizing. I bet the top to bottom number is different than the side to side number.
How does the crank look.
