Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - main or rod bearing rap.
Old 11-17-2012, 05:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 95chevy406 View Post
Crank was turned .010 on rods and mains and the big ends were honed out.are regular .010 undersize bearings good or do i need ones for the honeing done
No special bearings are needed. The honing that was done put the big end back to stock specs. The way it's done is a small amount is removed from the parting surfaces, then the big end is reassembled and honed back to stock spec. So when all's said and done you have a stock spec rod big end.
