Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - main or rod bearing rap.
Old 11-18-2012, 08:03 AM
BigEd36's Avatar
BigEd36 BigEd36 is offline
Originally Posted by cobalt327 View Post
No special bearings are needed. The honing that was done put the big end back to stock specs. The way it's done is a small amount is removed from the parting surfaces, then the big end is reassembled and honed back to stock spec. So when all's said and done you have a stock spec rod big end.
How much does re-sizing shorten the rods center to center length? If the mating surfaces are both cut some that will increase the "in the hole" distance of the pistons.
