Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - main or rod bearing rap.
  #16 (permalink)
Old 11-18-2012, 07:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by BigEd36 View Post
How much does re-sizing shorten the rods center to center length? If the mating surfaces are both cut some that will increase the "in the hole" distance of the pistons.
This depends on how far out of spec the rods is and whether material was removed from both the rod and cap or just the cap. So to answer you, it could be anywhere from several thousandths down to a tenth or two. I feel that checking/correcting bend and twist is as important. Problem is, some shops either don't or can't do this.
I would like to say using an aftermarket forging will cure all the problems associated w/resizing rods. But in this imperfect world we live in, even new rods can be out of spec, so they should be thoroughly inspected before use.
