main or rod bearing rap. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-18-2012, 07:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by BigEd36 View Post
How much does re-sizing shorten the rods center to center length? If the mating surfaces are both cut some that will increase the "in the hole" distance of the pistons.
This depends on how far out of spec the rods is and whether material was removed from both the rod and cap or just the cap. So to answer you, it could be anywhere from several thousandths down to a tenth or two. I feel that checking/correcting bend and twist is as important. Problem is, some shops either don't or can't do this.
I would like to say using an aftermarket forging will cure all the problems associated w/resizing rods. But in this imperfect world we live in, even new rods can be out of spec, so they should be thoroughly inspected before use.
  #17 (permalink)
Old 11-18-2012, 08:07 PM
Originally Posted by 95chevy406 View Post
The guy was running vortech heads.i have a set of 64cc 87 350 heads shaved .040 with ss valves and steam holes drilled.with the pistons and heads i have the compression will be around 10.9:1
That is too much compression. For pump gas and iron heads about 9.5:1 will be on the safe side. You really need to measure the chambers of those heads. You cannot figure compression ratio without knowing piston head volume and cylinder head chamber volume. If your heads were 76cc chambers and you milled .040 from them you probably have about 67 cc chambers. With a 7cc flattop pistons and .015 head gasket you would have about 9.792. You might have to use 89 or 93 octane gas depends on how your timing is setup. If you have a motor with 18cc dished pistons and using those heads your compression would be about 8.760. Factory pistons with the same heads and gasket would be 8.443 compresssion ratio.
standard or undersize rod/main bearing??? stevetankl Engine 5 06-16-2012 07:13 AM
Cadillac rod & main bearing clearances 327NUT Engine 5 04-05-2011 12:22 AM
What rod/main bearing sizes on a 90' 305? ace_012 Engine 3 05-27-2010 11:04 AM
Rod and Main bearing ? 6426yy Engine 8 03-25-2006 06:26 PM
GM main & rod bearing clearances Sagacious Hotrodding Basics 1 10-09-2004 11:38 AM
