major bbc problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 12:02 AM
427cutlass's Avatar
major bbc problems
i just got my 496 on the road, blew the tranny yesterday, swaped in new one and took it for a good drive. it seemed to have an engine miss, then i was at a stop light and put the car under load(about 1800rpm) and i heard a loud POP! so i limped it home and under load it did this POP a couple more times. THis is a new engine and combination, and i just installed msd distributer and msd 6al box. also just installed an electric fuel pump with return style regulator. Its got me confused,,, mabe fuel boiling? NEED HELP ASAP
thanks Ryan
Old 08-04-2008, 06:00 AM
31 five window
Last journal entry: grill and rear end
If you have a flat tappet cam check to see if you rounded a lobe.
Old 08-04-2008, 06:02 AM
Guy Hiltz's Avatar
Are you 100 % certain that the plug wires are in the right place,and on good & tight ?? If any are a bit loose,it could cause this problem,and this is assuming that you have good wires.Check this first,a loose wire will cause the problem you are describing.
Guy
Old 08-04-2008, 06:25 AM
major bbc problems
check you rocker arm movement
you may have a bent push rod or broke a valve spring
Old 08-04-2008, 11:23 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Right,
check to make sure that your timing chain was installed correctly, I fired up a bbc once and the thing ran great but half the pushrods were bent because the timing set was installed incorrectly.
Piston to valve clearance can be an issue with Big Blocks
Old 08-04-2008, 11:56 AM
Pull the valve covers go through your rockers and make sure nothing is amiss. I suspect you will find the culprit there. Double V seems to have been there. I know I have.
Old 08-04-2008, 12:36 PM
427cutlass's Avatar
plug wires are good, its a soild roller so does not need breakin... if it was a valve or somthing i would think it would do it all the time not radomly.. im thinking mabe the msd box...
Old 08-04-2008, 01:11 PM
Even if your trouble isnt in the valve train, break in has nothing to do with piston to valve clearance. If it is solid roller I guess you would have already had the valve covers back off to set your hot valve lash and you would have noticed it then.
Old 08-04-2008, 03:38 PM
427cutlass's Avatar
found problem... mag pick up wires between distributer and box were getting radial interferance
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 05:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
