Major C6 Issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2004, 02:27 PM
BigBlockBabe's Avatar
Missing You
Major C6 Issues
Ok, here's the rundown for anyone who hasn't heard me talking about the Bronco for the last 3 years. 1978 Bronco, 429/C6.
(Sorry this is lengthy, I feel you need the whole story on how the tranny has been acting)
My dad is having issues with the C6. Ok, when we first fired up the 429, and drove it, the 1-2 shift was too soft? If you laid into the throttle and got the R's up, it wouldn't shift until you let off. Even shifting manually you could feel something wrong. My dad and brother decide its not got enough modulation (or maybe he said too much modulation?) so dad buys a B&M shift kit. Get that in, and drive it and right out of the driveway its like boomboom and its in 3rd. It ran right through 1st and 2nd gears. Not good.
Oh and when he pulled the valve body out the first time, the fluid was pink like strawberry milk. He said it might have gotten water in it from sitting 3 years in the truck - he did have plastic covering the input? shaft.
He pulls the valve body out to see if maybe he left a check ball out or something, puts it back in (he may have left out the shift kit and made it normal again, I don't know) but drive it again and it feels like 2nd gear is slipping and the shifting is still not right. I talk to my brother and he said that he got the feeling that dad pieced the C6 together with parts from 2 transmissions. So I borrowed a book from a friend of mine that has all the pressures and stuff so dad can check the tranny.
Dad thought the valve body was just messed up, and got the valve body out of another C6 and when he checked the pressures everything was great, we were all fired up because he thought he'd found the problem and that he wasn't gonna have to pull the tranny out.
There's no reverse now. None. You can put it in reverse and at idle it kinda rolls back, but you rev it up, and nothing, sounds like its in neutral. Reverse was fine before and the forward gears were messed up. Now the forward gears have good pressure, but reverse is not there.
(Oh and I have no idea if this has any bearing on the problem, but dad said he almost put too much cam in it, like it doesn't have enough vacuum.)
Well? Any ideas? My dad is totally stumped on this one. Too bad we can't somehow fab a 727 in it, he can build the crap out of some Dodge trannies.
(And I don't know if this has anything to do with it or not, but could the transfer case somehow mess with how the tranny is acting?)
Old 02-29-2004, 02:56 PM
badknuckles's Avatar
you talkin to me?
if it is shifting fine now and you have no reverse i would say you got another bad valve body.
or its time for a rebuild.
Old 02-29-2004, 03:23 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Re: Major C6 Issues
The vacuum (or lack there of) can have a major playing role on the upshift action, but would have no effect on reverse.
If he can build a Dodge tranny he only needs the right parts and a book for the C6, he should breeze through that one too.
The transfer case would have no effect at all on how the transmission is acting, you either have a 203 or a 205 t-case, and it only relies on the output of the transmission, and the position of the shifter.
Old 02-29-2004, 06:47 PM
airworld2's Avatar
c6 trouble
no reverse , wrong year valve body ????? could also be stuck 2-3 shift valve....
water in the tranny fluid is trouble, damage will be imminent
airworld2
