Major Overheating with Sbc 355 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 11:34 AM
Chevz28's Avatar
i have a 84 chevy camaro z28, first thing is, i was driving it for a long time with a SBC 400 that was bored .40 over, street cam, edlebrock performer intake, edlebrock 600 carb, edlebrock water pump and never had a problem with overheating. Now, i rebuilt a 350, bored .30 over to be 355, with a 495 to 502 lift race cam, 202 camel hump fulie heads and with same intake, water pump, carb and with the same radiator, shroud, solid fan as before.
there is no heating, power steering or emissions - just alt, water pump and crank.
the 355 was free flow (w/o tstat) for racing ( 1/4 mi - 13.2s) and would heat up to 220 right after the race still running, shut off then would cool down.
then i put a 160 tstat in it so that i can drive again, let it warm up to drive, stays around 150 to 170 for about ten or so mins, then gets up to 180 and stays there for a few then gets to 200 after a couple mins and that is with out stopping and starting, i have never drove it farther than 200 to see wat it does.
when its cold outside it stays around 175 for a longer period but then starts to get hotter.
would like some tips to see wat i could do to fix this because here soon it will be the only thing for me to drive.
Thanks Mark
Old 01-14-2011, 12:33 PM
Chevz28's Avatar
so put the 180 tstat in it and see wat it does?
intake is aftermarket so does not have that inlet water port
im not sure on base idle and the specs for the cam i do not have with me at the moment
i have tested the cooling system and found nothing to be wrong
not sure on the chin spoiler, i took everything out that was behind front bumper that was in front the radiator when i first started driving it, nothing on the car or cooling system was changed when new motor went in.
Old 01-14-2011, 03:04 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Here's some pics of what you should have on your car.
Cole
ID:	51700   Click image for larger version
Old 01-14-2011, 03:08 PM
Chevz28's Avatar
thats wat i do have on the car, i just took out everything behind that
Old 01-14-2011, 04:01 PM
RippinRon's Avatar
The chin spoiler is a piece of plastic that hangs down behind the front fascia. It directs air up to the rad. Without it you get no cooling when you are moving. I know from experience.
Old 01-14-2011, 04:11 PM
eloc431962's Avatar
Wiki Edits: 37
That's right Ron, My bad don't know what i was thinking i bought a new Z 2/8 in 82 , but the piece you have to have is a smaller black piece that's goes underneath the front piece i posted, And it will sit back just alittle it will not be right out front it is under the front a little bit. JMO
Look at the pic below and you can see it and know what i am talking about.
Cole
Old 01-14-2011, 04:40 PM
Chevz28's Avatar
is that something that i could make?
Old 01-15-2011, 08:50 AM
Frisco's Avatar
Glad To Be Here
Checking/setting the timing is the first thing I would do. Having the timing even slightly retarded will cause the engine to run hotter than 'normal'.
F-BIRD'88 has given you excellent advise as to the thermostat and re-installing the air dam as well as suggesting the timing.
Old 01-15-2011, 10:05 AM
RippinRon's Avatar
I found these on thirdgen.org.
ID:	51708   Click image for larger version
Old 01-15-2011, 02:02 PM
malc's Avatar
Living At The Speed Of Life
Just a strip of aluminum.
Old 07-10-2013, 05:53 PM
Fbird88 can i PM you to discuss the timing issue regarding over heating?
Old 07-11-2013, 12:22 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Why don't you start your own thread and discuss it on the board for all to see, you may be able to help someone with the same issues.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
64nailhead (07-12-2013)
IFS help! major delima. silver86 Suspension - Brakes - Steering 20 01-16-2009 09:58 AM
i need of major help 32 duce Engine 3 11-25-2007 06:52 PM
Major C6 Issues BigBlockBabe Transmission - Rearend 3 02-29-2004 05:47 PM
Major Overheating Problem BigJeepAZ Engine 12 06-05-2003 06:51 AM
