Originally posted by: slammed 57
Boy! Do I Need Help. I Have A 57 Chevy Pick Up Which Has A Jim Mayers Mustang Ii Front End On It With A Manual Steering Rack On It , Finally Scraped Up Enough Cash To Purchace A Mustang Ii Power Rack. The Only Problem Is The Power Rack Housing Where The Steering Shaft Enters Is Hitting The Vertical Frame That Connects The Motor Mount To The Mustang Ii Crossmember. The Only Thing I Can Think Of Is To Notch Out The Vertical Motor Mount Frame, Unless Someone Has A Better Idea,
Hi!
Still having that problem? I found i useful write-up to help you. DIY on how to replace as steering rack. here is the link --->
http://autorepair.about.com/od/other.../aa071004a.htm
Good luck!
