Major Power Steering Problem ,please Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2010, 05:16 PM
slammed 57's Avatar
Last journal entry: t
Boy! Do I Need Help. I Have A 57 Chevy Pick Up Which Has A Jim Mayers Mustang Ii Front End On It With A Manual Steering Rack On It , Finally Scraped Up Enough Cash To Purchace A Mustang Ii Power Rack. The Only Problem Is The Power Rack Housing Where The Steering Shaft Enters Is Hitting The Vertical Frame That Connects The Motor Mount To The Mustang Ii Crossmember. The Only Thing I Can Think Of Is To Notch Out The Vertical Motor Mount Frame, Unless Someone Has A Better Idea,
ID:	44132   Click image for larger version
Old 02-25-2010, 08:18 PM
notch and box it sounds the easiest way and its safe too . as when you box it the strengh will be restored if its curvedyou can use a section of pipe wall to make it look nicer .
Old 02-25-2010, 08:36 PM
slammed 57's Avatar
Thats what i was thinking, thanks so much
Old 10-01-2010, 02:17 AM
New Member
Hi!
Still having that problem? I found i useful write-up to help you. DIY on how to replace as steering rack. here is the link ---> http://autorepair.about.com/od/other.../aa071004a.htm
Good luck!
Power steering pump bracket problem race10 Engine 3 02-26-2008 11:13 AM
power steering alignment problem StevenC Engine 3 05-29-2006 01:22 AM
Steering Lash Adjustment Problem GCD1962 Suspension - Brakes - Steering 1 12-30-2005 09:23 AM
4x4 steering problem adrock430 Suspension - Brakes - Steering 10 12-05-2005 06:39 AM
Problem solved, '46 Panel Steering Bluepen Suspension - Brakes - Steering 2 01-20-2005 08:05 PM
