Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Major transmission leak....HELP!
Old 05-06-2004, 05:51 PM
darom darom is offline
Chris, I am glad you found your leak and it is a cheap fix as well.
Are you using a manual body to switch gears or using an electrical signal to downshift? Why did you leave the kick-down cable out?
