Major transmission leak....HELP! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2004, 10:41 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Hey guys,
I went out for a drive in the S-10 today and found another problem. After beating on it a little the transmission begain to hemorrage oil everywhere. It was like taking out a drain plug. From what I can tell there is a bad leak in the front of the transmission in the pan area. After some work, I found that when I pour more oil in it runs right out without the engine running. It looks to be running out of the pan gasket area, but the gasket is in place and the bolts are tight. I just want to know if any of you know of a plug or something that could come out on the passenger side of a TH350. It is possible that the oil is coming from above the pan in the dipstick area, but it is not coming from the dipstick and I can not see anything else that would leak. My fear is a case crack since I can not see anything wrong.
I will not have a chance to get it apart until Friday and I am pretty sick about it so I just thought I would see if any of you had any ideas.
Thanks,
Chris
Old 05-05-2004, 10:50 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I believe the little vent tube runs toward the pasenger side from up top.
Old 05-06-2004, 07:24 AM
TurboS10's Avatar
Wiki Edits: 2
I think you are right. But this leak is at the pan level I think. The oil runs out about as quick as I pour it in and there is not oil up high. It is all at the pan rail. I have had vent tubes blow oil before, but never anything like the quantity that this is.
Thanks,
Chris
Old 05-06-2004, 10:23 AM
Have you checked your kick-down cable plug/mount? My friend's Camaro tranny leaked bad, we jacked up the car and saw that he had snapped the kick-down plastic insert on the tranny by twisting the cable (he tried to route it with the cable attached to the tranny case).
Regards,
Denis
Old 05-06-2004, 12:27 PM
TurboS10's Avatar
Wiki Edits: 2
Hmmm.....have not looked at that. It does not have a kick down cable at all. The guy who built my transmission plugged the holes. It has not leaked until now, but I guess it is a possibility that a plug came loose. Thanks for the tip, I will give it a look when I get under there.
Chris
Old 05-06-2004, 01:00 PM
camaroman7d's Avatar
The vent tube is on the drives side and I doubt that is your problem. Are you sure you din't blow the dipstick tube out? If not, there is noting else on the side that would cause this unless you broke the tranny case or the pan.
Chris you should really look into a th400 for the kind of power you are making. You are going to be changing th350's like you change shoes. After breaking a couple of pro built th350's with only ~500HP, I built my own th400 and it is holding up well to a lot more power.
Royce
Old 05-06-2004, 01:24 PM
TurboS10's Avatar
Wiki Edits: 2
Royce, agreed on vent tube. The dipstick tube is still in place. It is a Lokar and is a perfect fit with double orings. After some thought, I dont see how the trans would still operate if the case cracked because it seems it would have all kinds of internal pressure leaks. I did pull the truck on the trailer under its own power. The leak is definately not related to pressure as well. We jacked up the passenger side and it quit leaking. Let it down level and it pours out untill oil level goes down.
It is funny you have had better luck with TH350's. I went through a couple TH400 rebuilds and switched to a TH350 on my 57 with no problems. Of course I think that was a pump failure problem from increased pressure. I am not using a brake so I am hoping the TH350 will live until I go with a Powerglide. The friend of mine who built this transmission has run TH350's behind 700+HP big blocks. Of course, like you say, it takes a set of clutches once in a while. High gear being the main problem from my understanding.
Later,
Chris
Old 05-06-2004, 04:26 PM
TurboS10's Avatar
Wiki Edits: 2
Well, Darom hit the nail on the head. I just went out and crawled under the truck and checked the kickdown plug......It was not there. The damed cable end that was in the hole fell out. Should be making boost again tomorrow morning
Thanks Guys,
Chris
Old 05-06-2004, 06:18 PM
Right on easy and cheap fix. I have shattered a th 350 case and was still able to drive it, so don't thin a broken case will stop you in your tracks but, for it to leak as much as you mentioned ot would have to be a major hole.
If the th350 works for you stick with it. I just don't know anyone that can make them live reliably behind big power (500 or more HP) maybe in a light car. The sprags just can't take the abuse.
Royce
Old 05-06-2004, 06:51 PM
Chris, I am glad you found your leak and it is a cheap fix as well.
Are you using a manual body to switch gears or using an electrical signal to downshift? Why did you leave the kick-down cable out?
Denis
Old 05-06-2004, 07:58 PM
TurboS10's Avatar
Wiki Edits: 2
It is a manual valve body. There was an old cable end in there, but I think the plastic flange that holds it in must have gotten broken on installation or something because it is gone now.
Chris
Old 05-06-2004, 09:59 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
You mean the vent tube is on the left?
Now why didn't you look a little harder the first time instead of thinking the worst? You had us all worried there for a minute!
Oh well, it's not like I never changed a pan gasket only to find out it was the kickdown cable leaking......
We'll be expecting an update on your next flight too! Maybe a nice couple of pics of some serious damage next time, huh?
Old 05-07-2004, 06:04 AM
TurboS10's Avatar
Wiki Edits: 2
Sorry for the worry
When I could not find anything visibly wrong, I just thought the worst. I will remember next time this happens. I was looking at it on the side of the road laying in a puddle of oil when I first made the post. I was frustrated to say the least.
Chris
