make your headlights twice as bright cheap!
and cut down the chances of electrical fire The headlight relay is a helpful upgrade. When I did it, I used an aftermarket relay and spliced in to the high beam and low beam wires under the hood, to the headights. The objective is to have as little voltage drop as possible, between the battery and the lights. So that means large gauge wire to the relay(s), and tapping directly off the battery side of the solenoid. Get the headlight and dimmer switch, and all that small gauge wire connecting them, out of the headlamp circuit - the only contacts in the circuit will be the relay contacts.
| The Following 2 Users Say Thank You to unclebill For This Useful Post: | ||
banditosmith (05-19-2013), C-10 (11-28-2012) | ||
| The Following User Says Thank You to gearheadslife For This Useful Post: | ||
banditosmith (05-19-2013) | ||
Thanks for the tip uncle bill!
Good diagram too. |
I did the same thing, but in "stealth mode." I have a 1-wire alternator, so I gutted the voltage regulator and stuck the relays in there.
My testing, using my Nikon's light meter, showed that the low beams increased by 100% in intensity and the high beams increased by ~66%. ![]() ![]()
^^That's pretty nifty right there.
thats pretty slick there toddalin
even if it didnt make em brighter
it cuts out all that juice running through the switches my antique switches got dangerously hot and i didnt want to fry em. |
| CHEAP HID Headlights | D M N | Electrical | 5 | 01-12-2007 12:58 PM |
| How do I make my Headlights Brighter??? | mason71 | Electrical | 12 | 04-07-2005 06:09 PM |
| Anyone make a cheap rebuild kit for '64 PG? | Crank | Transmission - Rearend | 3 | 09-13-2003 08:29 PM |
| Me and my bright ideas... | Gearhead forever | Hotrodders' Lounge | 8 | 07-29-2003 05:20 PM |
| not bright | shortbed | Electrical | 2 | 10-26-2002 09:29 AM |
