makeing your own english wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2009, 10:22 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
i read a thread on here about building your own mig welder
and someone mention about someone named twisted minis
building his own English wheel and i would like to know how
to do this so if any one on here knows this person or knows
how to do this please let me know
thanks buggmann
Old 04-09-2009, 11:11 PM
for what the harbor freight e wheel costs, it's almost pointless to try and make one yourself unless you need a larger capacity.
I built my ewheel from a kit. it's really simple. basically a c-frame made up of 2x4 1/4" wall tubing with gussets in the corners. add a couple straps of 1/4" plate with a solid pin to hold the top wheel in place.
the bottom wheel sits in a saddle made up of 3/8" plate. that sits on some square tubing that slides inside another piece of square tubing. an acme screw at with a nut welded inside the larger square tubing acts as the pressure adjustment. another nut welded to the bottom of the acme screw with 3 pieces of bar welded to it act as a handwheel. there are three thumbscrews welded to the outer square tubing to take up the slack in the inner square tubing.
the wheels themselves can either be fully rounded or with a calibrated flat spot on them (there is a guide somewhere on the 'net for how big to make the flat spot).
Old 04-09-2009, 11:21 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
the one on hf is not to bad on the price
but money is tight that is way i was going
to make my own but i might just buy one
were did you find your kit
Old 04-09-2009, 11:37 PM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
The framing isn't so tough to figure out - lotsa examples on the web for the design - here's 2 styles from HF
Harbor Frieght started selling a lower priced model which for around 300.00 a couple of years ago - but I've heard they "move" a bit and need to be re-inforced.
A nice page on using and re-inforcing the HF "economy" wheel
http://www.jamesriser.com/Machinery...el/Finally.html
But I noticed recently while window shopping the HF site that they are selling a Heavy Duty model for 560.00.
This type of design much more stable and typical of higher end units.
Old 04-09-2009, 11:54 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
i don't need something to big its just for home use
i would like to learn how to use tools like this so i don't
have to pay some one to do it for me and it needs to
fit in to a small two car shop i think the one hf has for
sale will do but were would i need to add the brace at
Old 04-10-2009, 12:43 AM
http://www.jamesriser.com/Machinery/...l/Finally.html
The benchtop style that HF sells (149.00) - you could do a similar treatment to strengthen the frame...
HF English Wheel Search
Old 04-10-2009, 07:33 AM
I bought my kit on ebay about 4 years ago. I think it was around $130 or so for everything. it made an ewheel about the size of the mid-sized harbor freight model. it has a very similar construction to the bench top model except much more stiff.
i can take a picture if you really want to try building one.
Old 04-10-2009, 08:15 AM
cboy's Avatar
Last journal entry: Finished
Here's a thread from right here on HR.Com about the HF wheel and the reinforcement points.
And a couple quick pictures of what is involved.
There is quite a bit of info around the web on how guys have turned the HR wheel into a pretty good working tool. Each wheel seems to have its own little quirks so each person does it a little differently. Mine now works pretty well...although I am just a hobby user and haven't really pushed the limits on it yet.
Always learning...and sharing what I've learned.
Old 04-10-2009, 01:15 PM
buggmann's Avatar
Wiki Edits: 2
buggmann
that is all it will be for me also just something new to
learn i think the ewheel from hf will do nice and i think
what all the people on here have been a big help
thank you buggmann
Old 04-15-2009, 08:57 PM
Last journal entry: Cobra build
There is a web site called wheelingmachines.com, it is a great place to find out about wheeling, and metalmeet.com for metal working. One of those sites has complete plans and pictures for building a wheel.
Old 04-16-2009, 10:46 AM
speede5's Avatar
go fast, turn left!
At those prices, and with minor reinforcement why re-invent the wheel?
Wheel Tub/Quarters crusherdbuzz Body - Exterior 2 04-02-2008 01:05 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 01:15 AM
Home made english wheel? polkat Body - Exterior 4 02-25-2006 04:31 PM
English wheel ianhealey Garage - Tools 11 08-19-2004 08:30 AM
