-   -   making a 6 cylinder street rod (http://www.hotrodders.com/forum/making-6-cylinder-street-rod-143438.html)
trigger piston 08-13-2008 02:56 PM
I got a 300 6 cylinder and Iwant it to scream I was wondering If you could put a 250 crankshaft in a 300 6 cylinder because the 250 got a built proof bottem end. and does any body know about the cut up 351 custom head you can put on it.
Henry Highrise 08-13-2008 03:04 PM
click here and look around http://www.hotrodders.com/forum/for...head-89738.html
oldbogie 08-13-2008 04:01 PM
Other way around, the 300 has the bullet proof bottom end with a fully counter-weighted forged crank, meatier rods, and thicker block castings. The 240 is a cast crank, light rods and thin wall cast block.
The 302/351 heads are a race only mod. The never solved, seldom mentioned problem is coolant leakage at the join points. While a race engine will stay dry enough for an afternoon, this isn't something you do on a commuter car.
Bogie
matt167 08-13-2008 04:35 PM
I think he might be talking about the small 250 6 from the Falcon engine series.. which are bullit proof because of the 7 mains and the good oiling system... however a 250 crank will not fit a 300 as they are 2 completly diffrent engines...
There is a new aluminum high performance cylinder head that will be released at some point for the 240/300.. produced by www.classicinlines.com
tomslik 08-13-2008 05:59 PM
ford motorsports USED to sell an aluminum head for the 240/300 sixes.
wasn't made by ford but i THINK it was mfgerd by one of the fuel guys, anderson maybe?
guess they used 'em in comp class....
