Making a 64 ford pickup 2wd into a 4wd??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2009, 07:06 PM
okay i just got a 64' 1/2 ton ford pickup from this guy on craiglist for 250$ and the only drawback is that it is 2wd, and it is not a unibody thank god.
(the only reason i got it was because the 61 ford i have is in need of so much work with school in all i just couldnt do it, i was planning on making a monstrous 4x4 with about 24'' lift and around 30-40'' of flex, i already put all last summer into it, and barely made a dent so thats the history of that)
i want to put a 4wd system into it, but i am not really sure what i initially need to do? i have a few question so ill try to to organize this better
it has a pathetic little 302 in it, which would be switched for either a 390, 427, 428, or 460. So will a Big block going in that year and model?
another question is just in general what is really involved in this process?
do i a new tranny (obviously besides one for a BB), diff steering shaft, what is the deal with driveshafts (shorter or longer ones), will it mess with anything in the engine comparment (the fender wells, shock towers, etc)?
i know a little but i was just asking to see if anyone had better knowledge about an actual 64' ford pickup and not just 4x4 truck in general, thank you all who help me with this, your effort is much appreciated
USING LATE 80'S FRAME FOR A 1937 FORD PICKUP DIGGER Body - Exterior 24 08-24-2013 07:25 PM
1940 Ford pickup box and door questions? Skiman Hotrodding Basics 10 04-04-2011 05:50 PM
33 Ford Pickup Shootest Introduce Yourself 2 02-22-2006 10:41 PM
help with 1935 ford pickup raf Introduce Yourself 2 10-27-2005 03:30 PM
40 Ford Pickup Body Parts enemyace Body - Exterior 1 03-23-2003 10:54 PM
