making custom oval exhaust. muffler help please. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2010, 10:16 PM
Well me and my dad want to do something a little challenging, were going to be making some oval exhaust for my firebird. taking 2-2 1/2" pipe cutting it in half then welding flat plate inbetween. ANYWAY what kind of muffler should i be using? or could i possible just fab one up? if so what type of baffles should i use to maximize flow?
motor is a pontiac 455 mild street motor.
Old 12-03-2010, 10:23 PM
ericnova72's Avatar
More for Less Racer
I believe SpinTech sells oval tubing, would be a lot easier than making it. Speedway Motors and Shoenfeld headers may also.
I've never seen an oval inlet/outlet muffler, the systems that Spintech has hav a oval to round connector and use regular mufflers.
Old 12-03-2010, 10:46 PM
Yea ive seen the kits from spintech there pretty cool, ive just got alot of fabrication experience and i think it would be fun to make my own hahah just curious on what im going to do for a muffler system. im going to run the exhaust out the side in front of the rear tires.
Old 12-03-2010, 11:02 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
cut a glasspack and weld it back together just like you are doing with the pipe
Old 12-03-2010, 11:42 PM
dodge it's Avatar
Last journal entry: yep
hey
take a look at a box for a delta style muffler .
like a flowmaster or a thrush .
i just cut a thrush welded muffler apart to make it smaller to fit on my buddys car .
you could cut the end off most delta style mufflers and fab new end plates for your oval set up i really like the thrush welded i push them on everyone .
i like the idea, diffrent is cool and don't buy a kit fab it up yourself thats what hot rodding is about .
Old 12-04-2010, 06:26 PM
found a muffler that flowmaster makes with oval inlets so i think ill use those.
This is going to be a fun project ill keep yall updated with pictures!
Old 12-04-2010, 09:56 PM
Silverback's Avatar
Boost Retard
Spintech makes oval inlet/outlet mufflers, the oval eliminator mufflers:
custom exhaust for a ford ranger w/5.0 srgaspacho Engine 1 07-06-2003 10:25 AM
Custom Exhaust Question / Help KevNJ Engine 7 03-30-2003 08:37 AM
Any ideas if i can get a custom exhaust for my 84Z28? Rubberman2003 Engine 9 10-30-2002 07:37 PM
Exhaust sizing help needed for 454HO with EFI vernw Engine 4 03-29-2002 11:59 AM
custom exhaust for 36 ford coupe bomo Engine 5 12-07-2001 05:49 AM
