Making detailed exhaust diagram? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2006, 05:13 PM
BMM BMM is offline
Hello.
I figure I am low on money right now, but whats the point of sitting still, so here we go. I would like to make up an exhaust diagram, one which I could take to a shop and have them make.
I will eventually have a 350 Chevy block with headers under the hood, the car is 1986 Grand Prix. Right now however, it has a 3.8L with stock manifolds. Is there a way I could figure out where the Headers will end up after its all installed? Or would it be better to work backwards from the tailpipes?
How much space must I leave between gas/break/electrical lines?
When the pipes go over the rear axel, am I safest to take the pipe thats on there now, and duplicate the dimensions and angle of the bend for the new one? Which other ways of making sure there will be adaquate clearance are there?
Is getting a X pipe before hand and building to that safer than trying to find an X pipe to fit the exhaust?
Right now, the muffler lays with the wide part up and down, between the tank and rear axle. If I am using a dual setup, can mufflers go underside the floorboards in the rear? What should the lowest point of the car be? I am thinking the front bump skirt, but correct me if I am wrong.
I know it is alot of questions, but it would be a great help. Thank you for any info.
Old 11-17-2006, 09:59 PM
bigolblackie's Avatar
Take it to the shop put it up on the hoist,then both of you talk about what would work,bringing a drawing is not gonna cut it. Just my opinion.
Old 11-18-2006, 07:26 AM
I agree. Guys who fabricate exhausts are usually hands-on mechanics, and they don't relate well to drawings. They just want to put it up on the rack and look at it.
You might use a scale drawing to get some price estimates on pipe, and discuss alternatives (H pipe vs. X pipe), but they will always want to also take a look at it on the hoist.
Bruce
Old 11-18-2006, 11:11 AM
BMM BMM is offline
Fair enough. Too bad, I was kind of looking forward to being able to do something.
Thanks guys.
Exhaust System Sizing leejoy Engine 9 10-04-2006 07:38 PM
Exhaust Cross Connections Other Than X or H? JohnTN Engine 2 06-23-2006 06:04 AM
trying to pick exhaust 74huggerorange Engine 6 05-30-2003 04:57 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Making your own exhaust. 37Ford Engine 11 12-17-2002 11:38 AM
