Originally Posted by Ed ke6bnl
can you show us some bends, the ones I have seen have a rod welded to the inside and crush the inside part of the bend. Thanks ED
Looks good as you say for that purpose it is doing a fine job, I have one of the Harbor Freight cheapy bender for flat and rod which I like a lot also the bender like you have so this is helpful I also have the Hossfeld bender for round tube and pipe and lot of other uses. I want to add the cush rod in the cheopo HF bender, the bender I use the most for small brackets and smaller rod bending. Keep up the good work ED
