We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #16
Old 11-16-2003, 06:08 PM
2000n55 2000n55 is offline
New Member
krist to you have any pics of this pvc? is it the same as the burb in a previous post?
Old 11-16-2003, 07:31 PM
BigMac's Avatar
BigMac BigMac is offline
1949 Chevy Truck
A good friend of mine owns a real estate sign shop and orders it all the time. The easiest place to get it for me was there. It's 3mm which is about 1/8".
Old 11-17-2003, 06:20 AM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
Same as the burb in a previous post??? Not sure what you are asking...
I could take a picture if you really want, but it really wont help, theres really not that much to see. The plastic place i buy it from has the stuff in a bunch of different colors, red, blue, yellow..... We buy it in white because the white is a little bit cheaper than colored. Its just a 4'x8' sheet, 1/8" thick, with a fairly smooth surface.
Old 11-18-2003, 10:41 AM
ksshane's Avatar
ksshane ksshane is offline
Kris...
That is a great idea. I have been using that plastic for my business for a couple of years now, and I never thought to use it for making interior pieces.
Old 11-21-2003, 09:32 PM
pronash's Avatar
pronash pronash is offline
Kris: great idea. Since its just PVC I would assume that you can use the garden variety of PVC sprinkler pipe cement to glue shapes to door panels, etc. (Just like Rod Doors does but cheaper!)
Old 11-23-2003, 07:01 PM
I use our regular industrial spray adhesive the glue the plastic together. I once tried to peel apart two pieces i glued together and broke the plastic. So I would say the adhesive does the job. But i would also think PVC pipe glue would work.
Old 11-26-2003, 01:31 PM
Stinkin_V8's Avatar
Stinkin_V8 Stinkin_V8 is offline
Suburbanite Member
The stuff I used on my Suburban (mentioned above) seems pretty good for this but I'd like to find something a little easier to work with. This stuff almost has two layers to it, one smooth and one textured. Both layers are laminated together but tend to give problems when I heat and bend. The stuff cools very slowly, too. A bit thinner material would be good, and a harder plastic might be easier to work with as well. For my headliner, though, it's perfect since I don't need to heat it and bend it - the bows will hold it in place.
Originally posted by DesertPanel
He hasn't updated the site since August, but it looks very trick so far. If you're into old Suburbans or Panel Vans, check the whole site out. He's really kicking butt on this project.
Heh.. Thanks, DesertPanel. I got a bit sidetracked with dropping a Buick 3800 into my Fiero. Long story, but as soon as that's done I'll be back into the 'Burb, building interior panels. Drop me an email sometime.
Old 12-03-2003, 09:52 PM
Jag Daddy's Avatar
Jag Daddy Jag Daddy is offline
British Style with USA Muscle
Kris'
Since you heat it into shape is there any problems if you live in a hot climate? Does the stuff get brittle from thermal cycling after a while?
Sound interesting but living here in So Cal where in my area 100 degree temps are common place would have me a bit concerned. If it's 100 outside the car it's hotter inside!
Regards
Mark
Old 12-11-2003, 12:21 AM
The Sneak The Sneak is offline
I make interior panels for my work (camperizing full size vans) and the stock panels are flat 1/8 inch pvc. The sliding door sizes are very large, and provide ample material for almost any custom panel. post pics when you are finished.
Old 12-12-2003, 01:37 PM
yourownreality yourownreality is offline
You can always make a frame for the door out of wood, fiberglass, and AB foam to make the doors contours.
Look at this site for a full write up on make a door.
http://jlaudio.com/tutorials/mera/MERA_2003.pdf
You can get AB foam at most autobody suppliers and from selectproducts.com.
Jerry
Old 12-21-2003, 03:09 PM
powerglide_66's Avatar
powerglide_66 powerglide_66 is offline
Is the stuff you are talking about called
FRP(Fiberglass Reinforced Plastic)?
Old 12-21-2003, 03:20 PM
Who are you asking?
Old 12-22-2003, 12:01 AM
snkbyt's Avatar
snkbyt snkbyt is offline
ASE Master
Cristcustom is right on! The only way to go is the 1/8" ABS it can be glued if you screw up. Also like Alan said get the book Custom Auto interiors. Shows how the Pros make the sculptured effects. Workn on my 36 Ford 3 window interior now and 3, 4X8 sheets cost me 86.00 (Alaska money,hahah) They build the panels then glue on 1/4-1/2 poltfoam then put on the material. You can cut any design you want in the foam before covering. Also you can bend the ABS real easy with a propane torch and a little finesse, Ray
Old 12-26-2003, 03:23 PM
Hot Rod Up Hot Rod Up is offline
Custom User Text:
Guess I'm old school I use 1/8'' wood board
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
