I'm building a 1936 Plymouth coupe street rod and I have a 1985 Ford 5.0 and auto overdrive from a Lincoln Mark 7 I want to install in it. I will be running a performance intake and four barrel carb. on the engine (no fuel inj.) What do I need to have and to know to get the trans. to work correctly?
-AOD TV Linkage And Adjusment-[/b]</a>
www.windsor-fox.com/detail.cfm?id=CBL-TV-AOD <a href="http://www.tciauto.com/instructions/431000_inst.htm]-Proper TV Cable Adjustment- |
gary........ read , learn and follow the info on the sites that KULTULZ posted.
Very important that the TV linkage operation is correct for an AOD. Tony
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Building a 36 Ford 3 win with 351w (stroker 392)and AOD. Holley 770cfm.I just received a cable kit that has the carb mod(for Holley)and trans brackets from Total Performance if you need more info email me. Got their info but it's at work.
