making a grill insert help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-14-2011, 02:11 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by deadbodyman
something else I tried is aluminum strips 1/2' x 1/8" that looked good too but I liked the chrome a little better
1/8 x 1/2'' aluminum bars would look good as well.
They buff up nicely.
  #17 (permalink)
Old 12-15-2011, 03:56 AM
deadbodyman's Avatar
Wiki Edits: 11
Most of those type grills are painted on three sides and only the 1/8 stays so polishing isnt a big deal ......but aluminum is a lot harder to make bends in without an expensive shrinker /strecher that works without maring the surface but if its a straight shot it''ll work well too.Aluminum takes glues well too so if you dont have a tig it can still be done ez...Heres a few shots of the chrome faucet tubing. and a part of the grill I'm making..
ID:	60816   Click image for larger version
ID:	60817   Click image for larger version
ID:	60818   Click image for larger version
ID:	60819   Click image for larger version
  #18 (permalink)
Old 12-15-2011, 07:29 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
if you use tubing, you could use all or part of it as a cooler
  #19 (permalink)
Old 12-15-2011, 08:11 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
http://www.dundeeproducts.com/chart.html
A steel tubing chart for your information..
http://www.metalsdepot.com/products/alum2.phtml?page=tube&LimAcc=$LimAcc
Aluminum tube sizes for information..
making the grill a cooler could be good idea...
Sam
  #20 (permalink)
Old 12-15-2011, 08:45 PM
You're right on the money! We make vette grilles at work - I'm not allowed to post pictures of how we do it, but what you got there is how a lot of people form metal.
  #21 (permalink)
Old 12-15-2011, 08:53 PM
1971BB427's Avatar
I built an aluminum tube grille for a friend's truck using the remnants of our old TV antenna. I almost threw it out when I re-roofed the house, but I'm a packrat, and it just looked like something I might use parts of someday.
Wasn't but a couple months later that we were looking to build his grille and I thought of the antenna in the scrap metal pile. I got the antenna and the portaband out, and we did some measuring. The tubing wa weathered, so as we cut pieces we polished them with 400 grit, then buffed them on the wheel.
Once we had the support pieces made we JB welded the tubes into the supports and let it sit. Turned out great, and the cost was under $20 for some aluminum bar tock, and JB Weld. We also clear coated it, as I figured the aluminum would weather and dull again.
  #22 (permalink)
Old 12-15-2011, 09:44 PM
Wiki Edits: 11
LOL ,Thats funny I dont care who you are....
  #23 (permalink)
Old 12-15-2011, 10:10 PM
Wiki Edits: 11
This grill is something I've been thinking about while I'm doing the metal fab on the nose of this car , Now that I know it'll work I have a plan after I finish the metal work,gotta think ahead,,,I still have to mock up an aluminum grill just to see how it looks but this will work,it aint cheap though ,about 120.00 for the whole grill and thats just the mock up and who knows how long it'll last....aluminum strips on the other hand would be a lot cheaper and might look just as good and hold up a lot longer.....espiecally if they're clear coated....This is just the easiest option to start off with for some quick results...
  #24 (permalink)
Old 12-21-2011, 05:22 PM
Alumicraft's Avatar
'36 Chevy truck grille
Hello,
I build aluminum grille inserts everyday and the '36 Chevy truck is a regular production piece for me. I have a grille shell at the shop to build the insert in. It comes with all the mounting brackets etc.
I build it with 1/8" x 3/8" custom extruded bar stock that has a rounded leading edge. It's available as a front edge polish with satin sides, fully polished or chrome plated.
The '36 Chevy truck grille is one of 85+ different grilles we build for Chevy, Dodge, Ford, Plymouth, Willys, etc. Sorry, but we don't build any Buick, Olds or Pontiac inserts.
If you'd like more info, send me a PM through this forum. In keeping with the guidelines of this forum, I'm not allowed to post any contact info in this reply, but a Google search of my username should get you there
Thanks,
Dan Baker
Last edited by Alumicraft; 12-21-2011 at 05:33 PM. Reason: removal of business contact info
  #25 (permalink)
Old 12-22-2011, 05:50 AM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
grill ideas
You can also go to a ornametal steel shop, they have all kind of square and round rods thar are twisted or embellished in some way for fencing, and they are very inexpensive. I like the 1/4 twisted square rod myself.
  #26 (permalink)
Old 12-22-2011, 09:43 AM
making chev grill insert
Interesting project, my buddy is making grill insert for his '33 Sedan
He is using 3/16 key stock and cut two sets of bars(left and right).
On a metal table he started from the center and using small nuts, one on each side of tack as spacers, and clamped each bar as it was tacked into place, , kept adding bars till one side was done, then same process to other side. Care not to get going too fast, so nothing got hot. He then repeated process for the top and bottom tacks.
Hope this makes sense
  #27 (permalink)
Old 12-23-2011, 02:33 PM
prime time
You Fellows Made My Day With The Grill Insert Thanks Lead Shed
roof insert john General Rodding Tech 2 10-26-2008 11:25 PM
how to insert a picture 71 Ventura Off-Topic 1 05-21-2008 06:27 AM
Build this tubular grill insert for under $20 cboy General Rodding Tech 8 01-22-2008 11:58 AM
Making Progress or making more work for myself?! Weimer Hotrodders' Lounge 5 02-15-2004 03:11 PM
Dash Insert zonk Hotrodders' Lounge 6 10-22-2003 06:09 PM
