Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Making my 63 GT Hawk breath.
Old 03-08-2013, 06:14 PM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by Farriier1951 View Post
What carburator(s) can I use on a Studebaker 289 v-8 engine that will fit the Studebaker 4 barrel manifold?
The 1963 Stude with a 4 barrel should be the Carter AFB if this is original. In that case the current Edlebrock 1406 or 1405 should be reasonably correct. These are 600 CFM units the 06 has an electric choke the 05 manual. You will probably have to fiddle the connections to linkage and fuel supply but basically it should bolt on.
Bogie
