Making my 63 GT Hawk breath. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2013, 09:49 PM
What carburator(s) can I use on a Studebaker 289 v-8 engine that will fit the Studebaker 4 barrel manifold?
Old 03-08-2013, 07:14 PM
The 1963 Stude with a 4 barrel should be the Carter AFB if this is original. In that case the current Edlebrock 1406 or 1405 should be reasonably correct. These are 600 CFM units the 06 has an electric choke the 05 manual. You will probably have to fiddle the connections to linkage and fuel supply but basically it should bolt on.
Bogie
Old 03-08-2013, 09:07 PM
Banned
I could be wrong but I think the 1405 is a 500 cfm carb and either model can have manual or electric choke. The 1406 is a good street carb that I have use a few times in the past. It's finicky with larger cams though.
An Open Apology, xntrik, automotive breath and HBB. 71C10 Engine 14 02-11-2007 07:42 AM
Help BG Tech Can;t Breath Can't Tune Ratchet Engine 34 09-29-2005 06:25 PM
breath and get drunk? akm Hotrodders' Lounge 7 08-26-2004 10:18 PM
Time to take a breath Bluepen Hotrodders' Lounge 19 10-14-2003 08:51 AM
How t o breath new life into an 86 350 canine1566 Engine 2 09-25-2002 09:02 PM
