We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 03-07-2005, 10:43 AM
brainsboy's Avatar
brainsboy brainsboy is offline
brains
Making own steering rods
I am re-designing my steering rods with heim joints, I was wondering if any one knows if the steering rods used need to be a strong steel. I went to a stock car site and they had some in aluminum which seems weak to me. I plan on driving this on the street, but also at the drag strip. I dont like turns so, the car is probably not going to see any type of cornering and it weights under 2400lbs. The aluminum is anadized which would look real nice, I'm just worried if its going to be strong enough. If I go with steel can I use just normal cold rolled steel and weld on bungs?
Old 03-07-2005, 11:17 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
willys36@aol.com's barnstar
Wiki editor
Last wiki edit: Fiberglassing
Wiki Edits: 20
I use CR steel tubing and thread it. I bought 11/16" LH and RH taps (fit standard tie rod ends) and make my own. I don't recall the tubing size but I take my tap down to the steel yard and there isa size that is nearly perfct for the taps. Just need to run a drill bit through it to clean it up. No special materials required.
Old 03-07-2005, 11:35 AM
brainsboy's Avatar
brains
Wow, thats a pretty big tap. You can keep it straight doing it by hand? My heim joints are 5/8" shaft so its a little but smaller. I wonder what size tubing I would need for that. How much do you think a tap that big would cost?
Old 03-07-2005, 12:05 PM
Wiki editor
Wiki Edits: 20
5/8" is 10/16" so my 11/16" isn't that much bigger. It isn't that hard to start and run the tap by hand. Enco lists a RH 5/8"-24 plug tap for $8.34. Didn't find a LH tap but I'm sure they can supply one for a similar cost.
Old 03-07-2005, 12:10 PM
astroracer astroracer is offline
STUPID is as STUPID does...
astroracer's barnstar
Wiki editor
Last wiki edit: Crankshaft Coalition Wiki
I got a set of 3/4" LH & RH taps off eBay for $15.00 shipped. That was half the price for just a LH tap...
For sizing check out the required drill sizes for the tap. There is a max and min size and as long as you keep the I.D. of the tubing within these specs you will be good.
Just a note: Do NOT use black pipe. Use Drawn Over Mandrel tubing. It's more expensive but the Black Pipe is very soft and will not hold up.
Mark
Old 03-07-2005, 12:12 PM
brainsboy's Avatar
brains
I found some taps 12.85 each, they have both LH and RH. But they have 3 types. Taper, plug, and inline. Any idea what the difference is?
Old 03-07-2005, 12:42 PM
Wiki editor
Wiki Edits: 20
Plug is the type you want. They are the 'standard' style that come in sets with a small chamfer on the tip to facilitate starting the thread.
Old 03-07-2005, 01:30 PM
brainsboy's Avatar
brains
thanks willy
Old 03-08-2005, 04:58 PM
wally8 wally8 is offline
You shouldn't have any problem with aluminum.
Is this the site you were on: http://www.colemanracing.com/catalog/index.php?cPath=2_132
They also have lengths of untapped material with the appropriate i.d. for tapping so you could make your own if you wanted. For $10 apiece though, why bother.
Wally
Old 03-08-2005, 05:21 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
OneMoreTime's barnstar
Wiki editor
Wiki Edits: 3
Tie rods and such
Speedwaymotors.com has ready swedged steel tubing in the lengths you may need..Just oder the tubes and the heim joints and away you go..For the price they want I cannot see making my own..
OMT
Old 03-10-2005, 08:19 AM
T2B T2B is offline
tie rods
I used some DOM (drawn over mandrel) tubing and some Pro-werks weld in bungs with the proper thread for my heim ends. Simple fast and effective. Have one on my 63 Scout and have not bent it off raoding. I think you could also use 5/8" x .156 DOM tubing and drill and tap. Check California Custom Roadsters.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Making own steering rods"
T Bucket Steering and Radius rods plans ken47 Suspension - Brakes - Steering 11 02-01-2007 05:39 PM
new rods or old rods? Blob Engine 12 02-03-2004 04:35 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 10:06 AM
Steering install help ets1945 Suspension - Brakes - Steering 18 12-21-2003 08:19 PM
Model a steering jforward Suspension - Brakes - Steering 4 08-27-2002 05:43 PM
