Making a pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2011, 05:31 PM
Making a pattern
My first upholstery project. I need help with making this pattern of the original. I did soak the pieces and then ironed them out. The inside corners are what I am unsure about. If I lay the piece flat the stretched corner stands up and then the pattern doesn't have enough material to match the center insert. If I swing the wing of the pattern out, then it bunches on the outside edge. How do I make an accurate pattern for this seat. On the original seat the center panel was held down with rubber bands, wire and listing, so the corners are obviously stretched.
ID:	55429   Click image for larger version
ID:	55430   Click image for larger version
Old 05-20-2011, 07:22 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I hope this makes sense to you. The outside piece needs to be compatible with the center insert. Overlap the rear and sides onto the outside edge of the insert by 1" all the way around, and sew a 1/2" seam all the way around. In this picture, if the cardboard is the insert, from the black line out is the piece that is sewn to it. Just make sure that the outside piece is plenty long to go all the way to the front of the insert. You can always cut it off if it's too long, you can't make it longer if it's short. Also.......you will go crazy trying to match up a lot of witness marks. Start in the rear center of the insert and sew to the end, then turn the piece over and sew to the other end. As long as both pieces finish in the same spot across from each other on both sides of the insert you will be fine.
Old 05-22-2011, 07:47 PM
The part that I can't understand is how to cut the material to start with. Do I stretch it to make the pattern?
Old 05-23-2011, 12:28 AM
Wiki Edits: 22
No, you don't want to stretch it, just follow the shape of the insert.
standard bolt pattern on duel pattern heads nskeeter99 Engine 1 02-15-2009 01:41 PM
Dual pattern Cam vs. Single pattern Cam Malibu73 Engine 7 02-13-2006 10:33 PM
Single Pattern VS Dual Pattern Lthompson Engine 20 02-20-2005 06:19 AM
dual pattern vs singel pattern martien bierlee Engine 3 01-19-2005 04:34 PM
Making Progress or making more work for myself?! Weimer Hotrodders' Lounge 5 02-15-2004 03:11 PM
