Making A Portable Welding Table - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2011, 08:50 PM
daveh's Avatar
Hey guys,
I'm making a portable welding table and I have a piece of 3/16" stainless steel and a piece of 3/16" aluminum for the top portion. Are they ok to use? I want to make sure that I won't have any issues like if I was using galvanized steel.
Thanks Dave
Old 08-13-2011, 08:59 PM
life is a temporary assignment
I have a welding table,, I used 1/2 steel on the top,, That way I can weld anything to it.... For making things... Then grind it off when I'm done..
Old 08-14-2011, 02:33 AM
bentwings's Avatar
bentwings
My small portable table has a 1/4 steel plate 2 feet x 3 feet. I just clamp it on or most of the time it just sit there. It's nice to weld stops and blocks to it. I also have a 1/4 in alum plate the same size that I use a lot.
Generally I clamp parts to the table and I can spin the table as needed. I can clamp it down as needed too.
cutting table JCAR Interior 6 08-06-2010 06:06 PM
Welding Table fatrat Garage - Tools 15 06-14-2010 07:02 PM
wooden periodic table "table" Jon Off-Topic 2 03-19-2006 04:17 PM
portable welding help stuck Garage - Tools 24 02-05-2005 08:50 AM
Looking for a table... iiibdsiil Garage - Tools 14 11-21-2004 02:39 PM
