making power with a 396 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 07:17 PM
Last journal entry: front clip
First time posting in this forum. I'm building 50 f1 ford with a IFS out of 87 Monte Carlo. I have a 396 that was given to me ( trying to use what i have ) it has a set of 454 rectangle port heads. Have a 700r4 trans and a 9" ford rearend with 373 gears. My question is what kind of hp can i get out this engine going 30 over ( don't know to much bout 396 ). Also the f1 has 4 link an airbag set with. Please help with this.
Old 01-14-2012, 07:31 PM
450hp should be made fairly easily.
10:1 cr, compcam 292H, headers, rpm intake, 750 holley, 3000 rpm stall should work well with the 3.73 gear and 700r.
will require domed pistons.
if the compression is low, then you could also bolt on a supercharger, but the 700r will have a tough time.
Old 01-15-2012, 04:21 AM
Thanks that's what i'll do and its enough power for cruising.
Old 01-15-2012, 07:14 AM
about what I was talking about.
http://www.racingjunk.com/Street/229...no-453-hp.html
how much power is my 454 making now? and what mods should be next? nfreas313 Hotrodding Basics 37 12-19-2011 12:22 PM
how much power is my 355 making? Tonkaboyrich496 Engine 1 06-30-2010 04:03 PM
bbc427 need help making big power dre1984 Engine 14 03-05-2010 11:28 AM
Want to know how much power your engine is making? Double_v23 Hotrodding Basics 219 02-23-2009 04:25 PM
Car not making power. 355_Rx7 Engine 12 10-22-2002 10:04 AM
