Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Making a realistic Deuce Firewall
Old 11-08-2009, 11:54 AM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by 1ownerT
What is your dual master cyl. from?
It looks like the old combo brake/clutch unit in the old 63 GMC I had.
Great job on the firewall!
That's exactly what it is. I'm using an Ansen dual pedal setup which is designed to use the early 60's GM pickup twin (brake/clutch) master cylinder. Just need to swap the innards from one side to the other to have the brake and clutch systems on the correct side (which takes all of 5 minutes) and then everything just bolts together. Don't for the life of me understand why Chevy's pedal linkage reversed the sides but that's just the way they did it.
