-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   Making a realistic Deuce Firewall (http://www.hotrodders.com/forum/making-realistic-deuce-firewall-168071.html)
Centerline 11-07-2009 09:33 PM
So... you say you have a fiberglass deuce body but the firewall is just a boring flat slab and you want something better. Well, if you want a realistic deuce firewall.... make one.
http://hotrodsandhemis.com/DeuceFirewall/DOUBLEa.JPG
Here's the before and after shot. If you want to see the entire "how I did it" story..... check the link below.
Project 32
NEW INTERIORS 11-07-2009 09:54 PM
Great job Centerline... :thumbup: Look's like the Originally.. ;)
matt167 11-08-2009 07:36 AM
cool.. looks just like it should
Frisco 11-08-2009 07:45 AM
Excellent work! :thumbup: :thumbup: :thumbup:
Your photos and commentary of your build are, as always, excellent. I am anxious to see your finished car and read about the first ride down the road.
ENJOY!!!
1ownerT 11-08-2009 09:06 AM
Project 32
What is your dual master cyl. from?
It looks like the old combo brake/clutch unit in the old 63 GMC I had.
Great job on the firewall!
Centerline 11-08-2009 11:54 AM
That's exactly what it is. I'm using an Ansen dual pedal setup which is designed to use the early 60's GM pickup twin (brake/clutch) master cylinder. Just need to swap the innards from one side to the other to have the brake and clutch systems on the correct side (which takes all of 5 minutes) and then everything just bolts together. Don't for the life of me understand why Chevy's pedal linkage reversed the sides but that's just the way they did it.
MARTINSR 11-09-2009 09:31 AM
Looking at how you did it, very cool. Where did you get those giant valve covers for a small block Chevy? :mwink:
Centerline 11-09-2009 03:13 PM
Hay! I'll have you know I had to fill in and finish grind two bullet holes in those damn things before getting them chromed. Probably from some Chevy guy. :rolleyes:
http://hotrodsandhemis.com/DeuceFirewall/IMG_1851a.JPG
wretched ratchet 11-09-2009 03:27 PM
no other explaination except that is "awesome and beautiful ART work" - - - kudos CL :thumbup:
