Making a realistic Deuce Firewall - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2009, 09:33 PM
Wiki Edits: 49
So... you say you have a fiberglass deuce body but the firewall is just a boring flat slab and you want something better. Well, if you want a realistic deuce firewall.... make one.
Here's the before and after shot. If you want to see the entire "how I did it" story..... check the link below.
Project 32
Old 11-07-2009, 09:54 PM
life is a temporary assignment
Great job Centerline... Look's like the Originally..
Old 11-08-2009, 07:36 AM
Wiki Edits: 31
cool.. looks just like it should
Old 11-08-2009, 07:45 AM
Frisco's Avatar
Glad To Be Here
Excellent work!
Your photos and commentary of your build are, as always, excellent. I am anxious to see your finished car and read about the first ride down the road.
ENJOY!!!
Old 11-08-2009, 09:06 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Project 32
What is your dual master cyl. from?
It looks like the old combo brake/clutch unit in the old 63 GMC I had.
Great job on the firewall!
Old 11-08-2009, 11:54 AM
Wiki Edits: 49
That's exactly what it is. I'm using an Ansen dual pedal setup which is designed to use the early 60's GM pickup twin (brake/clutch) master cylinder. Just need to swap the innards from one side to the other to have the brake and clutch systems on the correct side (which takes all of 5 minutes) and then everything just bolts together. Don't for the life of me understand why Chevy's pedal linkage reversed the sides but that's just the way they did it.
Old 11-09-2009, 09:31 AM
Looking at how you did it, very cool. Where did you get those giant valve covers for a small block Chevy?
Old 11-09-2009, 03:13 PM
Wiki Edits: 49
Hay! I'll have you know I had to fill in and finish grind two bullet holes in those damn things before getting them chromed. Probably from some Chevy guy.
Old 11-09-2009, 03:27 PM
wretched ratchet's Avatar
one full turn after it squeeks
no other explaination except that is "awesome and beautiful ART work" - - - kudos CL
Mold making questions ChrisMiddleron Body - Exterior 14 10-07-2008 02:03 AM
Help--Need to Cut a hole in Firewall trifivefan Body - Exterior 4 09-10-2007 10:19 PM
Making A Fiberglass Console For The First Time nightrain_rod Interior 4 03-07-2006 01:46 PM
Making Progress or making more work for myself?! Weimer Hotrodders' Lounge 5 02-15-2004 03:11 PM
Smooth firewall GearHead69 Body - Exterior 17 07-25-2003 10:26 PM
