making a remote fill brake reservoir - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 05:36 AM
is there any problem with drilling the side of my master cylinder at the top and tapping it for let say 1/8 pipe thread on the side and removing some of the center of the rubber gasket and run the lines from the threaded fitting to a remote reservoir. ED
Old 09-02-2009, 07:04 AM
302 Z28's Avatar
They do make replacement reservoir caps specifically for this purpose. I see no problems with what you want to do however.
Vince
Old 09-02-2009, 12:09 PM
An even cleaner solution would be to use a modern aluminum M/C with the plastic reservoir. Remove the plastic reservoir, tap the two fill holes in the M/C casting for NPT, and go from there.
Old 01-19-2013, 08:48 AM
Last journal entry: 1949 Chevy PU 3/4t barn find
Taping master cylinder for lines
Has anyone drilled and taped the case of a cast master cylinder for lines from a remote fill reservoir? How did that work? I have clearance issues for an after market mc cover.
Old 01-19-2013, 09:01 AM
As I just posted on another thread on this subject.
"This is my question, why do you need a remote fill? If your brake system is in good condition you don't need to be checking it all the time. If you have to pull a couple of screws up from the threshold moulding and lift the carpet to remove a little cover on the floor to add fluid when you do the brakes on your car, isn't that easy enough?
I have the master under the floor on my daily driver, yes it is kind of a pain to get to it but so is pulling off the wheel and front hub and drums checking the condition of the shoes. Cars had them under the floor along with the battery for years and years, is it ideal, no, but it isn't that big of a deal either.
Just my take on it.
Brian"
Old 01-19-2013, 12:47 PM
ogre's Avatar
the 'Duracell Project'
i added a remote reservoir when i had a line leak and didn't know it until i lost my brakes on the 11 power tour
it's nice to be able to check fluid level when i open the hood
i've had an underfloor mc on 58-59 trucks since the 70s never had a problem until i upgraded my brakes, and had carpet glued down over the mc cover.
go figure
back to his question, i don't see a problem with drilling the mc if it's done right.
you'd need a leak proof mc cover and the right lines.
don't like the reservoir hanging on my shaved firewall, but here it is
Old 01-20-2013, 07:32 AM
Real clean firewall, ogre. Ha mine looks like swiss cheese from the previous heater hack and factory holes over the years. No plan for a frame-off in the near future but they will get filled at some point.
go figure
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 08:20 AM
Making a Fast Remote Controlled Car Silentlion_69 Hotrodders' Lounge 9 12-02-2004 09:08 PM
making a metal brake 49olds Body - Exterior 3 06-04-2004 03:21 PM
