making a shift linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2012, 02:58 PM
i am going from a floor shift to a column shift.
i have a 350 th with a mid 80's gm column. i have no idea what the linkage
should look like . can some one help me out?
i appreciate all feed back and pics. thanks in advance
Old 06-07-2012, 07:30 PM
wiseguy50,
I take it that this is some sort of a "rat rod"?
Two ways to handle this. The first is to go to "Pick-N-Pull" or some place like it and find an 80's car to use the parts. I think there is a clevis shaft that is bolted to the frame and the transmission on the drivers side. This changes the direction of the shaft coming from the column down to the shifting shaft. There is also an odd looking piece of metal that connects to the clevis shaft and the shifting shaft. So when you pull down on the gear lever in the car it will twist the shifting shaft. All of these parts will be on the wrecked vehicle you would just need to bend the long rod leading from the column down to the clevis shaft so as to be able to clear headers, bell-housing, motor mounts etc.
The second way is to bend your own 5/16th or 3/8th round bar stock to fit. Then make the clevis shaft and attaching bracket from pipe and band iron welded together. You will need to have the funny shaped metal that attaches to the transmission shifting shaft.
Good Luck
Scholman
Poweglide shift linkage Luiz Transmission - Rearend 0 05-23-2011 02:23 PM
Shift Linkage - Does this look right? Torque454 Transmission - Rearend 2 03-05-2010 07:15 PM
Making carburetor linkage fred56 Engine 3 08-04-2007 04:59 PM
Shift Linkage starman141b Transmission - Rearend 3 12-22-2004 06:19 PM
shift linkage dusterbd Transmission - Rearend 5 09-15-2002 11:00 AM
