making a trans cross member - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2008, 07:56 AM
Vortech 4.3's Avatar
jack of all trades
i'm making a new trans cross member for my truck, so the dual exhaust will fit. its going over the exhaust pipe, then down under the trans. i'm going to cut & tig weld it together.
i have some new 1" .125" square steel. will that work ?
thanx
this is a pic of the stock setup with the headers.
Old 04-05-2008, 10:28 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
This is how I make all of mine.2'' X 2'' tubing.
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 06:37 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 08:58 PM
Cross member crack Guy Hiltz Suspension - Brakes - Steering 3 05-19-2006 08:43 AM
68 vette rear cross member stuck fire power Suspension - Brakes - Steering 0 02-14-2006 07:20 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
