Making your own spark plug cables - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2008, 09:37 AM
I'm tired of buying "supposedly" custom-fit spark plug cables that then turn out to be too long.
Has anybody ever made their own spark plug cables? What tools and supplies would I need? Any suggestions?
Rob
Old 10-04-2008, 09:42 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
I have purchased kits to make my own cables.
SummitRacing lists them. I went with Taylor 8.8 wires last time. I didn't buy the crimper tool, just used my hammer and some vice grips.
Old 10-04-2008, 10:02 AM
malc's Avatar
Living At The Speed Of Life
This tool used to be included in MSD wire sets made of aluminum, now they´re made of plastic.
This makes a real nice job of wire ends.
Old 10-04-2008, 10:13 AM
Frisco's Avatar
Glad To Be Here
Rob
The universal spark plug wire sets only need the wires cut to the desired length and the distributor cap terminal ends and boots attached. The spark plug ends are already attached.
A good hand held wire crimper/cutter/stripper tool is very helpful.
The crimping tool that malc has posted works very well but you still will need a stripping tool to remove the outer insulation and not cut the inner core.
A very liberal use of a lubricant (usually silicone grease although regular oil works as well) is needed to "slide" the boot back over the crimped terminal.
Last edited by Frisco; 10-06-2008 at 08:45 AM. Reason: reversed the end replacement statement
Old 10-04-2008, 11:06 AM
JeffB's Avatar
Originally Posted by Frisco
The universal spark plug wire sets only need the wires cut to the desired length and the spark plug boot and terminal attached. The distributor cap ends are already attached.
Try Armorall,works slick!
Old 10-04-2008, 11:39 AM
malc's Avatar
It is the distributor ends you have to attach, the plug boots are already there.
The tool I have shown allows you to strip the right amount of outer insulation and cut it to the right depth.
It´s done with the two holes you can see.
You just need to supply a sharp blade, insert the wire in the right hole until it stops, insert the blade in the slot and rotate the cable, presto job done.
Old 10-06-2008, 07:51 AM
Irelands child's Avatar
These are Taylor Spiro-Pro universals - and with a full MSD ignition are operating just fine. It takes a couple of hours to make up the wires, but for sure a lot better looking then the "custom fit".
My tools - a box cutter knife, a crimping tool and some silicone dielectric grease to get the boots on at the distributor end.
(I do like the tool that Malc pictured !!)
Irelands child
Old 10-06-2008, 09:35 AM
malc's Avatar
Here you go, buy one at Summit Racing.
MSD Mini Stripper Crimper. $4.80.
And at no extra cost instructions.
Old 10-06-2008, 10:12 AM
malc's Avatar
I used to have mine flying over the rocker covers but the last time I did wires I cut them just right and added a loom.
Neaterer
What spark plug should I run??? Ratoflic Engine 6 05-25-2008 09:18 PM
recomended spark plug.. screamin340 Hotrodding Basics 2 11-18-2005 08:17 AM
Spark Plug Wire shortage??? TheBreeze Electrical 10 11-04-2005 06:01 PM
Cylinder pressure vs. spark plug gap 70bird Engine 3 05-28-2005 09:25 PM
spark plug gap on BBC ratlover Engine 1 06-06-2004 06:53 PM
