-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Makita 18v lithium ion batteries (http://www.hotrodders.com/forum/makita-18v-lithium-ion-batteries-206765.html)
tech69 10-08-2011 09:41 PM
Just want to give you a heads up. These batteries are junk. They will die on you fast and each battery is $75. I had two go bad within a year. Just wanted to get that out cause I heard the same thing on line.
S10xGN 10-09-2011 03:53 PM
I've had a pair since Feb this year, we'll see...
Russ
jetnow1 10-10-2011 06:02 AM
I have the 18 volt drill and driver set with the batteries- have had the set
for 3 years used daily as a carpenter and have replaced one battery. There
are different series in 18 volt Makitas- I would not buy the ones that are
not Makita green. The driver is my most used tool! Jim
