FOR MALC <<>> NEW NASH METRO THREAD - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 11:14 AM
Bad Rat's Avatar
Last journal entry: SACRAMENTO AUTORAMA 02/05
Wiki Edits: 2
HERE it is Malc,, go for it, can you paint it too??? Thanks Bill
ID:	7435   Click image for larger version
Old 10-21-2005, 03:14 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
I don't mean any offense, but that top makes that thing qualify as a hideosity. It's got to come down out of the clouds.
Old 10-21-2005, 03:28 PM
malc's Avatar
Born To Be Mild
I did already and posted it here, The New Virtual Kustomz Thread!
Old 10-22-2005, 06:45 AM
cboy's Avatar
Last journal entry: Finished
Looks good in the new drawing BUT it's going to be tougher to do in real life. If you look close at the pic youl'll notice a full roll cage already installed. Dropping the top would require trashing all that fine work.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 10-22-2005, 07:51 AM
grouch's Avatar
Wiki Edits: 2
It looks like there are no front posts for the roll cage. I just ignored the roll bar while chopping the top in the photo (The New Virtual Kustomz Thread! which points back to chopping the top on a metro where MARTINSR and willys36 illustrated the process. It looks like the pie-shaped cut MARTINSR described would be needed if you intend to keep the rear window and cut it down). Couldn't the roll cage be cut at the bottom without too much pain? IIRC, he said he put a frame under it, so could the back mount points move forward on the frame without too much extra fabrication?
[Edited to add:]
Ever thought about sectioning? See attached.
Old 10-22-2005, 09:49 AM
Bad Rat's Avatar
Wiki Edits: 2
THANKS GUYS!!!!! The roll cage is going to be completely redone,, the body is removeable, so it will be easy to redo the cage,,,[ this is kinda like changing horse's in the middle of the stream,,turning out to be a nightmare] I intend to cut the cage out , chop the top, then remove the body and finish weld the cage,, as for cutting the rear portion of the top at the window area,, I think I will leave the wider bottom to the sail panel,, it leaves more mass, and makes the window look a lot smaller, I just havn't decided if I want to strech the top or lean the windshield back,, I kinda like the look of the leaned back posts, and less work,, I do know I need to get that fender cleaned up and some DP on it, tahnks BILL
That section job is cool,, a section along with a 3" chop would also require a hole in the top for the head to come through,, I feel like Saquile, O-Neal in a V/W already,
Old 10-22-2005, 11:27 PM
grouch's Avatar
Wiki Edits: 2
A laid-back windshield, in steps. Contrast changed for the top to show what was rotated. Windshield post rotated 15 degrees back from original position.
1 - rotation
2 - shortening front
3 - cleanup
Changes character without changing headroom.
Making it real is left as an exercise for the victim, er, owner. (In other words, I don't have a clue if it could actually be done this way).
ID:	7464   Click image for larger version
ID:	7465   Click image for larger version
Old 10-23-2005, 12:02 AM
Bad Rat's Avatar
Wiki Edits: 2
I'm not smart enough to use the programs that you guys use so I just made some copys of the car and got out my trusty exato blade and started chopping ,, and this is what I ended up with,, extended the roof and left the a pillers stock,, this is aprox 3"s . now all I need to do is find the caryon's
Bill
Old 10-23-2005, 12:51 AM
Bad Rat's Avatar
Wiki Edits: 2
Earl Schibe paint,
I'll NEVER laugh at a kids painting again, this is a metro with a Earl Schibe paint job,,
Old 10-23-2005, 08:48 AM
malc's Avatar
Born To Be Mild
I reckon one big body mod would suffice, the extended nose.
Old 10-23-2005, 11:25 AM
Bad Rat's Avatar
Wiki Edits: 2
MALC!! What program do you use?? Thanks Bill
Old 10-24-2005, 01:27 AM
malc's Avatar
Born To Be Mild
I´m using Adobe Illustrator CS2.
Old 10-24-2005, 11:00 AM
Bad Rat's Avatar
Wiki Edits: 2
Thanks,, BILL
Old 10-25-2005, 01:47 AM
malc's Avatar
Born To Be Mild
Hey Bill, what kind of power is the Stretch Metro going to have ?
Old 10-25-2005, 09:24 PM
Bad Rat's Avatar
Wiki Edits: 2
Hi Malc,, its going to have a blown innercooled 502 BBC, T 400 tranny, winters Q/C, rear, Thanks BILL
chopping the top on a metro Bad Rat Body - Exterior 40 12-16-2005 12:29 PM
pro street Nash Metro gmcarderII Hotrodders' Lounge 4 10-24-2001 05:00 PM
