mallory 6a ignition problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 02:33 PM
Maybe someone out there can help me out . I just installed a mallory 6a ignition control , and I am having a problem . I have gotten it to crank and run , but shortly after it starts cutting out then it will die . You can then give it a few minutes and will start up and do it again . Its like there is something getting hot inside the box and shutting off.My motor is a 350 with an hei distributor with an accel in cap super coil. Also when I set it up with original style module is cranks and run just fine.
Mallory Unilite Ignition Issue hulk21074 Electrical 21 12-06-2012 07:16 PM
Wow, Thanks alot Mallory Ignition!! 81MalibuWagon Engine 14 03-19-2011 10:42 PM
Mallory Ignition trouble 66Moostang Engine 3 08-06-2009 03:49 PM
Mallory Unilite Ignition System loiselle Electrical 6 04-29-2006 06:03 AM
Mallory ignition working but sucks! mde Engine 8 04-20-2004 09:01 AM
