is a mallory dist better than an accel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2003, 06:25 AM
New Member
Post is a mallory dist better than an accel?
which is better?i have a choice between a mallory dist with external coil and an accel dist with internal coil which is better both are same cost but which one will be best on my sb350?
[ January 17, 2003: Message edited by: 69chevelle ]</p>
Old 01-18-2003, 02:31 PM
Post
I have an Accel HEI super coil on my 65 Chevelle and it works great. Just changed the cap and rotor on it and it worked like a charm. I don't know too much about mallory but I would go with an Accel Super HEI.
Good Luck
Old 01-18-2003, 05:08 PM
dmorris1200's Avatar
doesn't play well with others
Post
I have been running Mallory distributors for years. I have run their dual-points in Chevys and Fords and I'm running a Mallory Unilite in my Mustang now. I don't have any personal experience with Accel but if you look at this link <a href="http://www.mrgasket.com/" target="_blank">Mr Gasket</a> you will see that both Accel and Mallory are now owned by Mr. Gasket Co. I use Mallory because I have always been satisfied with them and with the Unilite distributor adding a multi-spark HyFire box should take minutes if I decide to buy one.
BUILT FORD TOUGH
