any feedback on them,, good or bad, i found one, nib, for cheap. was wondering if I ought to snag it or hold out for a pointless dist., oh yeah, im there.
yeah, I hate setting a set of points, but 50$ us for a NIB distributor......thanks
The bad thing about Mallory stuff......the module kind especially ...... is the lack of parts support. Nobody but nobody has any pieces for them except Jegs or Summit. I ran Mallory for years but had to carry spares everywhere I went. I have a Pertronix in the 40 Ford now. It is easy to convert back IF you have a problem. Yes, I have the points and condenser (old stuff I took off) in the glovebox. ![]()
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
modules? he said dual point. you wont need parts for them and you can only run one set of points if you want to. a safety feature for points 4x4's. fry a set in the middle of nowhere, presto! new set already in there.
By the way the matchbook cover dissabling one set of points is so you can use a dwell meter to fine tune each set individually. Here is what I originally wrote for the Knowledge Base Installing a Dual-Point.
Alternative is to install Chrysler electronic components in ANY points distributor. Can keep the vintage look and get up to date tech. Probably the same result as a Petronix for much less money, ubiquitous repair parts. I am in the process of doing a photo session on a Chevy 235 6 cylinder distributor I am converting and will make the pics available to board members when done. Same procedure applies to V-8s and 4s. VERY easy to do and very cheap if you get junk yard parts!
thanks everone. DMorris, I've read that, even did it before I posted the thread
Willys36, I am really interested in what your doing. especially if its cheap and works. lets see that article......
| Recent General Rodding Tech posts with photos |
