Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - mallory dual points or hei ????
Old 08-14-2010, 12:01 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
All said and done for your application you are better off with the HEI.
Recurveing the stock HEI mechanical and vacuum advance curves will dial it in for a performance application. The MSD HEI coil is a great upgrade.
The dual point distributor is best used with a aftermarket ignition box (MSD etc )
That way the current across the points is greatly reduced and the ignition output power is jumped up a good bit. The points (used to switch the spark box thru the white wire) will last a long long time like this with a bit of routine lube on the points/cam rubbing block. (the current draw across the points in this configuration is minimum)
Best with vac adv for the street.
